Enabling or Disabling Guest Accounts
      A guest account must be enabled in order for a wireless device user to use the guest account to obtain guest network services.
When a guest account is disabled, it remains in the database. A disabled guest account cannot provide access to the network.
To Enable or Disable Guest Accounts:
            Do one of the following:
               - If you have GuestPortal Manager rights, log onto the controller.
               - If you have full administrator rights:
                     - From the top menu, click VNS. The Virtual Network
                           Configuration screen displays.
                     - In the left pane, expand the WLAN Services pane, click
                        the dedicated WLAN (Wireless Local Area Network) Service that provides the
                        temporary guest network services. The WLAN Services
                        configuration window for that service displays.
                     - Click the Auth & Acct tab, and
                        then click Configure. The
                           Settings screen displays.
                     - In the Guest Splash section, click Manage
                           Guest Users.
                     - The Guest Splash Administration
                        screen displays.
            In the guest account list, select the checkbox next to the user name of the guest account that you want to enable or disable.
            In the Account Enable/Disable section, click Enable Selected Accounts or Disable Selected Accounts accordingly. A dialog is displayed requesting you to confirm your selection.
            Click Ok. A confirmation message is displayed in the Guest Splash
                  Administration screen footer.
