Configuring an OSU Icon
This task outlines how to add, change, or remove icons to a list of icons that are associated with Online Signup. The icon list contains the metadata for the available icon files. The metadata defines the image size, language, type, and file name. The mobile device determines which icon in the list best fits the display and downloads the appropriate file. The list can be blank.
The NAI realm is used in cases where the OSU ESS (OSEN) SSID is configured. This allows the device to authenticate to the OSU OSEN SSID for access to the OSU server.
To add an icon:
  1. From the OSU SP Configuration dialog, click Configure.
    The Icon Configuration dialog appears.
  2. Click to expand in new window
    Graphics/Icon_Config.png
  3. Click Browse to navigate to the icon file. Then, click Open and Upload.
    The icon file is added to the Icon Configuration dialog.
  4. Select the icon and click Save.
    To delete an icon:
    1. Open the Icon Configuration dialog.
    2. Select the icon and click Delete.
    3. Click Save.
