Including Custom Apps
To add custom apps to the L7 Filter Rule
Definition dialog:
From the Filter Rule
Definition dialog, select L7.
Click Custom Web Application.
Click the plus sign and enter the following:
- Group. The group names are pre-defined standard Extreme Application Analytics™ signature groups. The group names are case-sensitive.
- Type. Type of
authentication. Valid values are:
- Signature. Standard IP address sent in
Signature.
- Layer 3 host name. Authentication based on User
Defined IP/subnet parameter in Layer 3 configuration. You can define up to 64 host name
patterns per controller or site. For more information, see Host Name DNS Support.
- Enter a Matching Pattern.
The Matching Pattern is the URL pattern that is associated with the
application (case sensitive, up to 64 characters).
- After entering the
Matching Pattern, the Name value is automatically provided.
Adding Custom Web Applications
Click OK.
The
list displays.
Custom Web Applications list
Select the checkbox and click OK to add the custom app to
the Name drop-down field on the L7 Configuration
dialog.
L7 Configuration: Custom Apps with hostname
rule
