Managing Certificates
To configure certificates, take the following steps:
Certificate Signing
Request
- Country name — The
two-letter ISO abbreviation of the name of the country
- State or Province name —
The name of the State/Province
- Locality name (city) —
The name of the city
- Organization name — The
name of the organization
- Organizational Unit name
— The name of the unit within the organization
- Common name — Click the
value you want to assign as the common name of the wireless AP (see Credential Parameters for credential
parameters and values).
- Email address — The email
address of the organization
- Key
Size — If the email address key size is different
from the default value shown, you can change it by selecting a new
value from the drop down menu.
Click Generate Certificates. The
AP 802.1x
Multi-edit progress window is displayed, which provides the
status of the configuration process. Once complete, the File Download dialog is
displayed.
Click Save. The Save as window is
displayed.
Navigate to the location
on your computer that you want to save the generated certificate_requests.tar
file, and then click Save.
The
certificate_requests.tar file contains a certificate request (.csr) file for
each AP.
Do one of the
following:
- For each certificate request, generate a
certificate using the third-party Certificate Authentication application.
This method produces a certificate for each wireless AP. Once complete, zip
all the certificates files (.cer) into one .zip file.
- Use one of the certificate requests and
generate one certificate using the Certificate Authentication application.
This method produces one certificate that can be applied to all
APs.
Bulk Certificate Upload
Click Browse. The Choose file
window is displayed.
of the file (.zip or .cer), and then click Open. The name of the file is displayed in the PFX, CER or ZIP Archive
box.
Click Upload and Set certificates.
Once complete, the Settings updated message is
displayed in the footer of the Wireless Assistant.
The 802.1x
EAP-TLS authentication configuration is assigned to the APs. The APs can now
be deployed to 802.1x enabled switch ports.
PEAP Authentication
PEAP authentication uses user ID and passwords for
authentication. To successfully configure 802.1x authentication of a wireless
AP, the AP must first be configured for 802.1x authentication before the AP is
deployed on an 802.1x enabled switch port.
In the Username drop-down list,
click the value you want to assign as the user name credential:
In the Password drop-down list,
click the value you want to assign as the password credential.
Parameter |
Value |
Name |
The name of the wireless
AP, which is assigned on the AP
Properties tab. The AP name can be
edited. |
Serial |
The serial number of the
AP. This setting cannot be edited. |
MAC |
The MAC address of the
AP. The setting cannot be edited. |
Other |
Click to specify a
custom value. A text box is displayed. In the text box, type
credential. |
To save your changes,
click Save.
The 802.1x
PEAP authentication configuration is assigned to the AP. The AP can now be
deployed to an 802.1x enabled switch port.
