Removing Guest Accounts
An already existing guest account can be removed from the database.
  1. To remove a guest account, do one of the following:
    • If you have GuestPortal Manager rights, log onto the controller.
    • If you have full administrator rights:
      • From the top menu, click VNS. The Virtual Network Configuration screen displays.
      • In the left pane, expand the WLAN Services pane, click the dedicated WLAN (Wireless Local Area Network) Service that provides the temporary guest network services. The WLAN Services configuration window for that service displays.
      • Click the Auth & Acct tab, and then click Configure. The Settings screen displays.
      • In the Guest Splash section, click Manage Guest Users. The Guest Splash Administration screen displays.
    Graphics/GuestPortal_Admin.jpg
  2. In the guest account list, select the checkbox next to the user name of the guest account that you want to remove.
  3. In the Account Management section, click Remove Selected Accounts.
    A dialog is displayed requesting you to confirm your removal.
  4. Click OK.
    A confirmation message is displayed in the Guest Splash Administration screen footer.
