Upgrading the Camera Image Manually
The AP3916ic is an 11ac Wave 2 AP with an
integral security camera that lets you extend your Wireless LAN and provide simultaneous
wireless service, BLE or 802.15.4 coverage and security in public spaces, such as classrooms
and offices.
The camera image (.dlf file) is distributed within
the controller builds. The AP manages the camera image — camera images are
automatically upgraded with the AP image upgrade when a new camera image is
available.
You have the option to upgrade the camera image
manually if necessary. To upgrade the AP3916ic camera image manually:
From the top menu, click
AP.
In the left pane, click
From the AP Software Maintenance
tab, under Download AP
Images:
Provide the necessary information to download the camera image
file.
Select AP3916-Camera as the Platform.
Click Download.
Under Upgrade Behavior, select Upgrade when
AP connects using settings from Controlled Upgrade.
Click Save.
The
Controlled Upgrade tab
displays.
Manually Upgrading Camera Image
Select the Controlled Upgrade
tab.
Select AP Platform: AP3916-camera.
Select the camera image file.
Click Camera Image
Upgrade.
