Viewing
Mobility Reports
The Mobility Domain is a virtual combination of Wireless LAN
Controllers (WLCs) grouped for the purpose of roaming. The controller
group consists of a Mobility Manager, Mobility agents, and a Backup Mobility Manager.
The Mobility Domain preserves information about user sessions, allowing users to
roam through the use of identity-based networking. A Mobility Domain can also provide
network flexibility and scalability.
When a controller has
been configured as a mobility manager, additional displays appear as options in the left
pane:
- Primary Manager
Mobility Tunnel Matrix — Displays a cross-connection view of the state
of inter-controller tunnels, as well as relative loading for user distribution across
the mobility domain.
- Client Location in Mobility Zone —
Displays the active wireless clients and their status.
- Backup Manager Mobility Tunnel Matrix — Displays a
cross-connection view of the state of inter-controller tunnels, as well as relative
loading for user distribution across the mobility domain.
- Remotable VNS — Displays the active
There are four possible reports available from the
Available Mobility Reports page
depending on the configuration of the controller. If the controller does not have
mobility enabled, it will just include the
Remotable VNS
report.
To view Mobility
Manager reports:
From the top menu, click
Reports.
In the left pane, click
Mobility.
Click the appropriate
mobility manager report:
- Backup
- Remotable VNS
- Primary Manager Mobility Tunnel
Matrix
The colored status indicates the following:
- Green — The mobility manager is in communication with an
agent and the data tunnel has been successfully established.
- Yellow — The mobility manager is in communication with an
agent but the data tunnel is not yet successfully established.
- Red — The mobility manager is not
in communication with an agent and there is no data tunnel.
