AP3916ic (Integrated Camera)
The AP3916ic is an 11ac Wave 2 AP with an
integral security camera that lets you extend your Wireless LAN and provide simultaneous
wireless service, BLE or 802.15.4 coverage and security in public spaces, such as classrooms
and offices.
The AP3916 can be mounted on the ceiling, wall or in a
junction/gang box. The integral ONVIF compatible security camera is connected to an internal
wired Ethernet port, and the AP provides policy enforcement control for
the wireless and wired connections.
The AP3916ic has the following
specifications:
- Integrated 2MP camera with resolution up to 1080p, with manual view
adjustment.
- Radios: Two concurrent Wi-Fi radios (2.4 GHz and 5 GHz) and one
additional radio that can operate as Bluetooth or 802.15.4.
- Antennas: Four internal single band Wi-Fi antennas and one internal
antenna for Bluetooth (BLE) or 802.15.4.
- LEDs: Six
- 802.3af compliant for full functionality. Optional AC adapter.
- Supports the 802.11ac and 802.11n wireless standards, with full
backward compatibility with legacy 802.11abg.
- 10/100/1000 Mbps operation.
- Adjustable mounting bracket (included) for drop-ceiling T-bar
rail.
- Optional mounts can be purchased separately for junction/gang box,
indoor wall and solid ceiling installation.
- Enabled for ExtremeCloud™ support.
ExtremeWireless support for the AP3916ic:
- Camera is powered by the AP3916i POE power supply:
- Camera port (CAM) can be assigned through policy to
B@AP or B@AC virtual network service topologies. Default and specific assignment is
supported. You can use policy definition and assignment to provide network segmentation
for network access and camera (CAM) functions.
- The AP3916ic's camera function is identified as
"EXTR2MP-CAM" device type. Filter the appliance client list to obtain a list of cameras
under the appliance management.
- The controller provides factory reset and restart functions for the
camera.
