Advanced configuration allows administrators to create a new VNS once the topology, role, and WLAN (Wireless Local Area Network) services required by the VNS parameters are available. The topology, role and WLAN services could be created in advance or could be created at the time of VNS configuration.
When you create a new VNS, additional tabs are displayed depending on the selections made in the Core box of the main VNS configuration tab.
When configuring a VNS, you can navigate between the various VNS tabs and define your configuration without having to save your changes on each individual tab. After your VNS configuration is complete, click Save on any VNS tab to save your complete VNS configuration.
If you navigate away from the VNS Configuration tabs without saving your VNS changes, your VNS configuration changes will be lost.The following procedure lists the steps necessary to create a VNS in advanced mode. Each step references a section in this document that describes the full details. Follow the links provided to go directly to the appropriate sections.
Print
                        this page
Email this topic
Feedback
