To configure a VNS, you can use one of the following methods:
When configuring a VNS, you can navigate between the various VNS tabs and define your configuration without having to save your changes on each individual tab. After your VNS configuration is complete, click Save on any VNS tab to save your completed VNS configuration.
If you navigate away from the VNS configuration tabs without saving your VNS changes, your VNS configuration changes will be lost.After the VNS wizard completes the VNS creation process, you can then edit or revise any of the VNS configuration to suit your network needs.
