| Field | Description |
| Serial # | Read-only. Displays a unique identifier (serial number) that is assigned during the manufacturing process. |
| Host Name | Read-only. This value, which is based on AP Name, cannot be directly edited. This value depicts the AP Host-Name value. If the AP Name value does begin with a number, for example when it is the AP serial number, the AP model is prepended to the value. This value is used for tracking purposes on the DHCP (Dynamic Host Configuration Protocol) server. |
| Name | Read-only. Displays the serial number of the AP. |
| Location | Define the location of the AP. When a client roams to an AP with a different location, Area Notification is triggered. The Area Notification feature is designed to track client locations within pre-defined areas using either the Location Engine (for more information, see Configuring the Location Engine) or the AP Location field. When the clients change areas, a notification is sent. Location functionality on the AP is useful when access to Extreme Management Center OneView is not available.  |
| Zone | Zone is a label that can be sent to a RADIUS server in place of an AP BSSID in the called-station-id attribute. It can be easier to base authorization decisions on the zone label rather than on the BSSID. Each AP can have its own Zone label although it is often useful to assign the same Zone to multiple APs. |
| Description | Type comments for the AP. |
| Topology | Read only. The Topology name with which the AP is registered. |
| AP Environment | Select — Indoor or Outdoor. This property is available for outdoor APs only, indicating where the AP is deployed. Note: The Outdoor APs can be deployed in both indoor and outdoor environments. |
| Hardware Type |
                 Select the hardware model of this AP from the drop-down menu.
                With ExtremeWireless v10.01 each controller is licensed in a specific domain.
                There are three types of domain licenses: FCC, ROW, EGY, and
                MNT. The ExtremeWireless user interface reflects the domain of the controller. The
                following are use cases for each domain:
| Application Version | Displays the ExtremeWireless release version. |
| Status | Approved — Indicates that the AP has received its binding key
                from the controller after the discovery process. If no status is shown, that indicates that the AP has not yet successfully been approved for access with the secure controller. You can modify the status of an AP on the Access Approval screen. For more information, see Modifying the Status of a Wireless AP.  |
| Active Clients | Displays the number of wireless devices currently associated with the AP. |
| Role | Displays the role for the AP.  Note: You
                  can only view these options here. You cannot change them.
Options include:
| Country | Click the country of operation.  Note: The antenna you select
                  determines the available channel list and the maximum transmitting power for the
                  country in which the AP is deployed.
