Installing the License Keys
This section describes how to install the license key on the controller. It does not explain how to generate the license key. For information on how to generate the license key, see the ExtremeWireless License Certificate, which is sent to you via traditional mail.
For more information on licensing, see Licensing Considerations.
You have to type the license keys on the Wireless Assistant GUI.
To install the license keys:
  1. From the top menu, click Controller.
  2. In the left pane, click Administration > Software Maintenance.
  3. Click the EWC Product Keys tab.
    The bottom pane displays the license summary.
    Product Keys Tab
    Graphics/controlled_software_keys.png
  4. If you are installing a temporary or permanent activation license key, type the key in the Activation Key box, and then click the Apply Activation Key button.
  5. If you are installing a capacity enhancement, type the key in the Option Key box, and then click the Apply Option Key button.
  6. To view installed keys, click View Installed Keys. The Installed Licensed Keys dialog displays.
    Installed License Keys
    Graphics/Installed_Licensed_Keys.png
