Accessing the Camera Web User Interface
Take the following steps to access the AP3916ic Web User Interface:
  1. Using your browser, navigate to the IP address of the camera.
    Find the camera IP address on the AP dashboard of the AP3916ic. Go to the AP list and click on an AP3916ic.
  2. Enter the camera IP address into your browser. The web UI displays.
    AP3916ic Web UI
    Graphics/ap3916_camera_gui.png
  3. Login with default credentials admin/admin The credentials are case sensitive.
    Later, you can customize these credentials. See User Management Settings.
    After the initial login, set a password in accordance with your IT policy regulations. Using default credentials is a security vulnerability for your network.
