When a switch is replaced and the original system ID and nickname is used, you must wait
            up to 20 minutes for the LSPs with the original system to age out. This is due to
            duplicate system ID and nickname detection. However, you can suspend duplicate detection
            on the replacement switch so that you can bring the switch into the network
            immediately.
            To temporarily disable duplicate detection on the replacement switch, perform the
                following steps:
                Copy the configuration file of
                    the original switch to the replacement switch.
                Power up the replacement switch
                    while it is not connected to the SPB network, that is, NNI ports are not
                    connected.
                Disable IS-IS on the original
                    switch, or remove the switch from the network.
                On the replacement switch, enter
                    the following Global Configuration command to suspend duplicate detection for up
                    to 21 minutes:
                    isis
                            dup-detection-temp-disable
                To check the remaining time, use
                    the show isis
                        dup-detection-temp-disable remaining time command.
                Remove the original switch from
                    the network.
                Connect the replacement switch
                    to the network.
