Display information about classless interdomain routing (CIDR) routes.
The following table defines parameters for the show ip bgp cidr-only command.
Variable |
Value |
<prefix/len> |
Specifies an exact match of the prefix. This variable is an IP address and an integer value from 0–32 in the format a.b.c.d/xx. |
vrf WORD<1–16> |
Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
vrfids WORD<0–512> |
Specifies a range of VRFs by ID number (the ID ranges from 0–512). |
