You must first onboard the VOSS device and configure any optional IQ Agent parameters before you enable IQ Agent.
- In the navigation pane, expand
- Select IQAgent.
- Select the Globals tab.
- Configure optional parameters as required.
- Select Apply.
- Select Enable.
- Select Apply.
Use the data in the following table to use the Global tab to configure the ExtremeCloud IQ Agent.
Name |
Description |
Enable |
Specifies whether IQ Agent is enabled. The default is enabled. |
Version |
Displays the ExtremeCloud IQ Agent firmware version running on the switch. |
OperStatus |
Displays the operational status of ExtremeCloud IQ Agent on the switch. |
ServerAddressType |
Specifies the address type of the ExtremeCloud IQ server address. |
Server/Address |
Specifies the ExtremeCloud IQ IPv4 address or DNS name. The default is hac.extremcloudiq.com. |
ServerAddressOrigin |
Specifies the origin for the ExtremeCloud IQ server address:
Address |
Specifies the proxy IPv4 address or DNS name. |
TcpPort |
Specifies the TCP connection port. |
UserName |
Specifies the proxy server password. |
Password |
Specifies the proxy server username. |
AssociationUrl |
Displays the association URL of ExtremeCloud IQ. |
PollUrl |
Displays the poll URL of ExtremeCloud IQ. |
MonitorFreq |
Displays the monitoring frequency, in seconds, of ExtremeCloud IQ. |
PollFreq |
Displays the polling frequency, in seconds, of ExtremeCloud IQ. |
LastOnboardTime |
Displays the last onboard time of ExtremeCloud IQ. |
LastPollStatus |
Displays the last poll status of ExtremeCloud IQ. |
LastPollTime |
Displays the last poll time for a successful attempt. |
LastMonitorStatus |
Displays the last monitoring status of ExtremeCloud IQ. |
LastMonitorTime |
Displays the last monitor time for a successful attempt. |
LastHealthStatus |
Displays the last health status of ExtremeCloud IQ. |
LastHealthTime |
Displays the last health time for a successful attempt. |
