For administrative and troubleshooting purposes, flush the routing tables.
To flush tables on a VRF instance for a port or VLAN, ensure that the VRF is associated with the port or VLAN.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
action flushIp
Flush the routing tables:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabitethernet 3/6 Switch:1(config-if)#action flushIp
