This topic explains how to obtain, activate, and transfer licenses on universal hardware switches.
For universal hardware switches, you can activate a license on the switch using either of the following methods:
Manual activation by obtaining the license activation file from the Extreme Networks Support portal.
Automated activation using ExtremeCloud IQ. For information about using ExtremeCloud IQ for bulk automated license activation, go to https://www.extremenetworks.com/support/documentation/extremecloud-iq.
You should have received by email a license voucher after your purchase of a switch. You will need the voucher ID number on this email to generate a license.
For manual license generation and installation:
Upgrade the switch so that it is running the most recent GA version of the software.
To download the latest GA software, visit the Extreme Networks Support portal.
Follow manual activation instructions for license generation available on the Extreme Networks Support portal: Products > Products Home > ExtremeSwitching > Universal > VOSS (for your switch) > Activation Instructions..
VOSS verifies the license and activates the features that correspond to the license category (MACsec or Premier).
For more information, see either of the following:
You can permanently remove a license, which allows you to transfer the license to another switch. This should only be done when preparing to return a defective switch for a replacement switch (RMA).
Revoke a License (using CLI)
Revoke a License (using EDM)
