Delete a dynamically learned route from the routing table if you do not want the switch to use the route. Exercise caution when you delete entries from the routing table.
Delete a dynamically learned route:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#no ip route 192.0.2.32 255.255.255.0 198.51.100.31 dynamic
Use the data in the following table to use the show ip route commands.
Variable |
Value |
<A.B.C.D> |
Specifies the IP address of the route to the network. |
alternative |
Displays the alternative routes. |
count-summary |
Displays a summary of the number of routes learned from each routing protocol for each VRF. |
preference |
Displays the route preference. |
-s <A.B.C.D/X> |
Indicates the IP address and subnet mask for which to display routes. |
-s default |
Indicates the default subnet. |
static |
Displays the static route information. |
vrf WORD<1-16> |
Displays the route for a particular VRF. |
vrfids WORD<0-512> |
Displays the route for a particular VRF number. |
spbm-nh-as-mac |
Displays the spbm route next hop as mac. |
Use the data in the following table to use the no ip route command.
Variable |
Value |
<A.B.C.D> <A.B.C.D> <A.B.C.D> |
Specifies the IP address, the subnet mask, and the next-hop IP address, respectively. |
dynamic |
Specifies that a dynamic route is to be deleted. |
enable |
Disables the route. |
local-next-hop enable |
Disables the local-next-hop option. |
preference |
Deletes the value of the route preference. |
next-hop-vrf WORD<1-16> |
Specifies the name of the next-hop VRF router. |
