Use the following procedure to create and configure an IKE Phase 1 policy.
Policy field descriptions
Use the data in the following table to use the Policy tab.
Name |
Description |
LocalIfIndex |
Specifies the Interface Index of the local address. Only port and vlan interfaces are supported. |
LocalAddrType |
Specifies whether the local address is an IPv4 or IPv6 address. |
LocalAddr |
Specifies the address of the local peer. |
RemoteAddrType |
Specifies whether the remote address is an IPv4 or IPv6 address. |
RemoteAddr |
Specifies the address of the remote peer. |
Name |
Specifies the name given to the policy. The name should be assigned while creating the policy. You cannot change the name after the policy is created. |
ProfileName |
Specifies the name of the profile that should be used for this policy. |
ProfileVersion |
Specifies the profile version used for the policy. |
PeerName |
Specifies the peer name. |
AuthenticationMethod |
Specifies the proposed authentication method for the Phase 1 security association. The default authentication method is pre-shared key. |
PSKValue |
Specifies the value of the Pre-Shared Key if the authentication method is set to PSK. |
DPDTimeout |
Specifies the Dead Peer Detection timeout in seconds. Default value is 300 seconds. |
P2PFS |
Specifies whether or not the perfect forward secrecy (PFS) is used when refreshing keys. To use PFS, select enable. The default value is disable. |
P2PfsUseIkeGroup |
Specifies whether or not to use the same GroupId (Diffie-Hellman Group) for phase 2 as was used in phase 1. Ignore this entry if P2PFS is disabled. The default value is enable. |
P2PfsDHGroup |
Specifies the Diffie-Hellman group to use for phase 2 when P2PFS is enabled and P2PfsUseIkeGroup is disabled. The default value is mod1024. |
AdminState |
Specifies whether the policy is administratively enabled or disabled. The default value is disable. |
OperStatus |
Shows is the policy is operationally up or down. |
RevocationCheckMethod |
Specifies the revocation check method as OCSP, CRL or none. |
