Use the following command to configure the VRRP version on an interface.
Switch:1> enable Switch:1# configure terminal Switch:1(config)# interface gigabitethernet 1/2
Configure VRRP version for the specified interface:
Switch:1(config-if)# ip vrrp version 3
Variable definitions
Use the data in the following table to use the ip vrrp version command.
Variable |
Value |
version <2–3> |
Configures the VRRP version (2 or 3) on the specified interface |
