The following table contains the default user names and passwords that you can use to log on to the switch using the command line interface (CLI). For more information about how to change passwords, see Security.
Table 1. CLI default user names and passwords
User name
Password
Description
rwa
rwa
read-write-all
rw
rw
read-write
ro
ro
read-only
l1
l1
layer 1
l2
l2
layer 2
l3
l3
layer 3
You can create up to a maximum of 10 CLI users for each role. For more information, see Multiple CLI Users for Each Role.
If you enable enhanced secure mode, the user names and passwords are different than the default values documented in the preceding table. For more information on enhanced secure mode, see Enhanced secure mode authentication access levels.
Important
Important
The default passwords and community strings are documented and well known. As a best practice, change the default passwords and community strings immediately after you first log on. For more information about how to change user names and passwords, see Security.
