Use the following procedure to delete accounts in enhanced secure mode.
You must enable enhanced secure mode in either the JITC or non-JITC sub-modes. As a best practice, use the non-JITC sub-mode because the JITC sub-mode is more restrictive and prevents the use of some troubleshooting utilities.
You must be an admin or privilege user to delete accounts.
Delete an account for jsmith:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#password delete-user user-name jsmith Switch:1(config)#save config
Variable definitions
Use the data in the following table to use the password delete-user command.
Variable |
Value |
user-name WORD<1–255> |
Specifies the user name. |
