This tab does not apply in all hardware platforms.
Perform this procedure to view information about the operating status of the power supplies.
- Click Power Supply Information.
Details Field Descriptions
Use the data in the following table to use the Details tab.
| Name | Description |
| Id | Specifies the ID number. This field is not supported on all hardware platforms. |
| Type | Describes the type of power used. |
| Description | Provides a description of the power supply. |
| SerialNumber | Specifies the power supply serial number. |
| HardwareRevision | Specifies the hardware revision number. |
| PartNumber | Specifies the power supply part number. |
| PowerSupplyOperStatus | Specifies the status of the power supply as one of the following:
| InputLineVoltage | Displays the input line voltage:
| OutputWatts | Displays the output power of this power supply. |
| InputOperLineVoltage | Displays the operating input line voltage. If the power supplies in a chassis are not of identical input line voltage values, the operating line voltage shows the low 110v value. This field is not supported on all hardware platforms. |
| InputPower | Displays the input power of this power supply. This field is not supported on all hardware platforms. |
