Configure ACE Internet Control Message Protocol v6 (ICMPv6) message type entries to have the filter look for packets of a specific ICMPv6 message type.
The ACL exists.
The ACE exists.
- In the navigation pane, expand the following folders:
- Click Advanced Filters (ACE/ACLs).
- Click the ACL tab.
- Select the appropriate ACL.
- Click ACE.
- Select the appropriate ACE.
- Click Proto.
- Click the Icmpv6 Msg Type tab.
- Click Insert.
- Specify the operator for the ICMPv6 message type.
- In the List field, specify the ICMPv6 messages to match.
- In the Count field, specify 1 through 100.
- Click Insert.
Icmpv6 Msg Type field descriptions
Use the data in the following table to use the Icmp6 Msg Type tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Oper |
Specifies the operator for the ACE protocol ICMPv6 message type. Equal (eq) is the only option. |
List |
Specifies the ICMPv6 message type (0–255), or echoreply, destunreach, sourcequench, redirect, echo-request, routeradv, routerselect, time-exceeded, param-problem, timestamp-request, timestamp-reply, addressmask-request, addressmask-reply, or traceroute. |
Count |
Specifies 1–100. Enables the ability to count matching packets. Use this parameter with either a security or QoS ACE. The default is disabled. |
