Use the following procedure to view the statistical graph of the IS-IS interface sending control packet.
- Select IS-IS.
- Select the Interfaces tab.
- Select an interface.
- Select the Graph button.
- Select the Interface Sending Control Packets tab.
Interface Sending Control Packets field descriptions
The following table describes the fields in the Interface Sending Control Packets tab.
Name |
Description |
Hello |
Indicates the number of IS-IS Hello (IIH) PDUs seen in this direction at this level. Point-to-Point IIH PDUs are counted at the lowest enabled level: at L1 on Layer 1 or L1L2 circuits, and at Layer 2 otherwise. |
LSP |
Indicates the number of IS-IS LSP frames seen in this direction at this level. |
CSNP |
Indicates the number of IS-IS Complete Sequence Number Packet (CSNP) frames seen in this direction at this level. |
PSNP |
Indicates the number of IS-IS Partial Sequence Number Packets (PSNPs) seen in this direction at this level. |
AbsoluteValue |
Displays the counter value. |
Cumulative |
Displays the total value since you opened the Stats tab. |
Average/Sec |
Displays the average value for each second. |
Minimum/Sec |
Displays the minimum value for each second. |
Maximum/Sec |
Displays the maximum value for each second. |
Last Val/Sec |
Displays the last value for each second. |
