This procedure only applies to VSP 8600 Series. For information about how to configure an IP address for a Segmented Management Instance, see Configure an IP Address for a Segmented Management Instance.
Configure the IP address for the management port so that you can remotely access the device using the management port. The management port runs on a dedicated VRF. As a best practice, redirect all commands that are run on the management port to its VRF.
The configured IP subnet has to be globally unique because the management protocols can go through in-band or out-of-band ports.
Configure the IP address for the management port:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface mgmtethernet mgmt
Switch:1(config-if)#ip address 192.0.2.31 255.255.255.0
Switch:1(config-if)#show interface mgmtethernet
Port Interface
PORT LINK PORT PHYSICAL STATUS
NUM INDEX DESCRIPTION TRAP LOCK MTU ADDRESS ADMIN OP
ERATE
mgmt 64 mgmtEthernet true false 1522 192.0.2.31 up up
Use the data in the following table to use the ip address command.
Variable |
Value |
<A.B.C.D> <A.B.C.D> |
Specifies the IP address followed by the subnet mask. |
