Perform this procedure to configure the rate limit of broadcast or multicast packets and determine the total bandwidth limit on the Extreme Integrated Application Hosting (IAH) port.
- In the navigation pane, expand the following folders: .
- Select the IAH port you want to configure.
- Select the Rate Limiting tab.
- In the AllowedRatePps column, enter a time duration for the specific Extreme Integrated Application Hosting port.
- In the Enable column, select true to enable rate limiting for the specific IAH port.
- Select Apply.
Rate Limiting Field Descriptions
Name |
Description |
Index |
Specifies the Extreme Integrated Application Hosting (IAH) port. |
TrafficType |
Shows the traffic type. The default is broadcast. |
AllowedRatePps |
Specifies the allowed traffic rate limit for the IAH port in packets per second (pps). |
Enable |
Enables or disables rate limiting for the specific IAH port. The default is false (disabled). |
