BFD for IPv6 interfaces is a demonstration feature on some products. For more information about feature support, see VOSS Feature Support Matrix.
Use the following procedure to display BFD statistics for IPv4 or IPv6 interfaces.
The following example displays BFD statistics for IPv4 interfaces.
Switch:1>show ip bfd stats
BFD staticstics - GlobalRouter
MY_DISC YOUR_DISC NEXT_HOP PACKT_IN PACKET_OUT LAST_UP LAST_DOWN
1 0 192.0.2.10 4661750 4620630 Mon Sep 6 15:31:15 2021 Mon Sep 6 15:28:08 2021
The following example displays BFD statistics for IPv6 interfaces.
Switch:1>show ipv6 bfd stats
1 0 2001:DB8:0:0:0:0:0:ffff 4661750 4620630 Mon Sep 6 15:31:15 2021 Mon Sep 6 15:28:08 2021
The following table defines parameters for the show ip bfd stats command.
Variable |
Value |
vrf |
Specifies a VRF instance by VRF name. |
vrfids |
Specifies a VRF or range of VRFs by ID. |
