View IP routes learned on the device.
- In the navigation pane, expand the following folders: .
- Click IP.
- Click the Routes tab to view IP routes learned on the device.
- If you want to limit the routes displayed, click Filter to show a smaller subset of the learned routes.
- In the Filter dialog box, select an option, or options, and enter information to limit the routes to display in the Routes table.
- Click Filter and the Routes table displays only the routes that match the options and information that you enter.
Routes Field Descriptions
Use the data in the following table to use the Routes tab.
Name |
Description |
Dest |
Specifies the destination IP network of this route. An entry with a value of 0.0.0.0 is a default route. The system can display multiple routes to a single destination in the table, but access to multiple entries depends on the table access mechanisms defined by the network management protocol in use. |
Mask |
Indicates the network mask to logically add with the destination address before comparison to the destination IP network. |
NextHop |
Specifies the IP address of the next hop of this route. |
AltSequence |
Indicates the alternative route sequence. The value of 0 denotes the best route. |
NextHopId |
Displays the MAC address or hostname of the next hop. |
HopOrMetric |
Displays the primary routing metric for this route. The semantics of this metric are specific to different routing protocols. |
Interface |
Specifies the router interface for this route.
Proto |
Specifies the routing mechanism through which this route was learned:
Age |
Displays the number of seconds since this route was last updated or otherwise determined to be correct. |
PathType |
Indicates the route type, which is a combination of direct, indirect, best, alternative, and ECMP paths.
Pref |
Displays the preference. |
NextHopVrfId |
Specifies the VRF ID of the next-hop address. |
