Configure ACE actions
DEMO FEATURE - Policy Based Routing (Redirect Next Hop) per VRF is a demonstration feature on some products. Demonstration features are provided for testing purposes. Demonstration features are for lab use only and are not for use in a production environment. For more information, see VOSS Feature Support Matrix.
Configure ACE actions to determine the process that occurs after a packet matches an ACE.
  • The ACE exists.
    enable
    configure terminal
  2. Configure ACE actions:
    filter acl ace action <acl-id> <ace-id> <permit | deny>
  3. Optional: Configure ACE actions to count matching packets:
    filter acl ace action <acl-id> <ace-id> <permit | deny> count
  4. Optional: Configure the QoS level for matching packets:
    filter acl ace action <acl-id> <ace-id> <permit | deny> internal-qos <0-7>
  5. Optional: Enable mirroring on destination MLT for matching packets:
    filter acl ace action <acl-id> <ace-id> <permit | deny> monitor-dst-mlt <1-512>
  6. Optional: Enable mirroring on a port for matching packets:
    filter acl ace action <acl-id> <ace-id> <permit | deny> monitor-dst-ports {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}
  7. Optional: Enable mirroring on destination I-SID for matching packets:
    filter acl ace action <acl-id> <ace-id> <permit | deny> monitor-isid-offset <1-1000>
  8. Optional: Configure the next hop IPv4 or IPv6 address for redirect mode for matching packets:
    filter acl ace action <acl-id> <ace-id> <permit | deny> redirect-next-hop WORD<1-45> [count | unreachable | vrf {WORD <1-16>}]
    Important
    Important
    Ensure you configure the ACE match rules so that you only collect the desired traffic. For example, routed packets.
  9. Optional: Configure the next hop IPv4 or IPv6 address for redirect mode for matching packets for a VRF. If the next hop is unreachable, you can also configure ACE actions to permit/deny packet dropping within the VRF:
    filter acl ace action <acl-id> <ace-id> <permit | deny> redirect-next-hop WORD<1-45> vrf WORD <1-16> unreachable <permit | deny>
  10. Optional: Configure the next hop IPv4 or IPv6 address for redirect mode for matching packets for a VRF. If the next hop is unreachable, you can also configure ACE actions to count matching packets, or to permit/deny packet dropping within the VRF:
    filter acl ace action <acl-id> <ace-id> <permit | deny> redirect-next-hop WORD<1-45> vrf WORD <1-16> unreachable <permit | deny> count
  11. Optional: Configure the QoS dot1 priority for matching packets:
    filter acl ace action <acl-id> <ace-id> <permit | deny> remark-dot1p <0-7>
  12. Optional: Configure the QoS phb and dscp for matching packets:
    filter acl ace action <acl-id> <ace-id> <permit | deny> remark-dscp [phbcs0 | phbcs1 | phbaf11 | phbaf12 | phbaf13 | phbcs2 | phbaf21 | phbaf22 | phbaf23 | phbcs3 | phbaf31 | phbaf32 | phbaf33 | phbcs4 | phbaf41 | phbaf42 | phbaf43 | phbcs5 | phbef | phbcs6 | phbcs7]
  13. Optional: Configure the mode when next hop is unreachable:
    filter acl ace action <acl-id> <ace-id> <permit | deny> unreachable [permit | deny]
  14. Ensure the configuration is correct:
    show filter acl action <acl-id> <ace-id>
    OR
    show filter acl config
    OR
    show filter acl ace
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#filter acl ace action 1 47 permit redirect-next-hop 192.0.2.5 unreachable deny count
Display the configuration using the show filter ace action command:
Switch:1(config)#show filter acl action
                           Ace Action Table (Part I)
Acl  Ace  AceName                  Admin   Oper    Mode   Mlt Remark  Remark
Id   Id                            State   State           Id DSCP    Dot1p
1    47   ace47                    Disable Down    permit 0   disable disable
                           Ace Action Table (Part II)
Acl  Ace  Redirect                                        Vrf                     Unreach Police  Internal
Id   Id   Next-Hop                                        name                    -able           Qos
1    47   2.0.0.0                                         GlobalRouter            deny    0       0
                          Ace Action Table (Part III)
Acl  Ace  Ipfix   Count   Log     CopyTo  Monitor  Monitor   Monitor
Id   Id                           Pcap    Dst-Mlt  Dst-Vlan  Dst-Port
1    47   disable enable  disable disable 1        0
                           Ace Action Table (Part IV)
Acl  Ace  Monitor           Dscp     Ttl      Monitor    Isid   QoS Remove-Tag
Id   Id   Dst-Ip                              Isid       Offset
1    47   0.0.0.0           ----     ----     ---        ---    ---
Displayed 1 of 1 Entries
Display the configuration using the show filter acl config command:
Switch:1(config)#show filter acl config
                          Filter ACL-ACE Configuration
filter acl 1 type inPort name "ACL-1-2/1"
filter acl port 1 2/1
filter acl ace 1 1 name "ACE_99"
filter acl ace action 1 1 deny
filter acl ace ethernet 1 1 src-mac eq 30:0:0:0:0:0:0:ffff
filter acl ace ethernet 1 1 ether-type eq 0x800
filter acl ace ip 1 1 ip-protocol-type eq 17
filter acl ace protocol 1 1 dst-port eq telnet
filter acl ace 1 1 enable
filter acl ace 1 2 name "ACE_100"
filter acl ace action 1 2 permit
filter acl ace ethernet 1 2 src-mac eq 30:0:0:0:0:0:0:ffff
filter acl ace ethernet 1 2 ether-type eq 0x800
filter acl ace ip 1 2 ip-protocol-type eq 17
filter acl ace protocol 1 2 dst-port eq ssh
Display the configuration using the show filter acl ace command:
Switch:1(config)#show filter acl ace
Variable definitions
Use the data in the following table to use the filter acl ace action command.
Variable
Value
<acl-id>
Specifies the ACL ID. Use the CLI Help to see the available range for the switch.
<ace-id>
Specifies the ACE ID. Different hardware platforms support different ACE ID ranges. Use the CLI Help to see the available range for the switch.
count
Enables the ability to count matching packets. Use this parameter with either a security or QoS ACE. The default is disabled.
<deny|permit>
Configures the action mode for security ACEs.
Note:
For each Security ACE, you must define one or more actions as well as the associated action mode (permit or deny). Otherwise, the security ACE cannot be enabled. There is no default configuration for Security ACEs. With QoS ACEs, the action mode is not configurable. QoS ACEs are always set to action mode permit.
monitor-isid-offset <1–1000>
Specifies the offset ID which will be mapped to the actual monitor I-SID where packets are mirrored.
Monitor I-SID = base monitor I-SID + offset ID.
The base monitor I-SID is 16776000.
remove-tag
Removes the outer VLAN tag for matching packets.
Note:
remove-tag is available only when matching packets are denied.
qos <0–5>
Defines the Quality of Service (QoS) profiles for the system.
The monitoring I-SID can support six different QoS levels from 0 to 5.
You can configure each QoS level individually.
The default value is 1.
internal-qos <0–7>
This variable is a QoS action.The default value is 1.
Configures mirroring to a destination port or ports. This action is a security action.
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.
monitor-dst-mlt <1–512>
Configures mirroring to a destination MLT in the range of 1 to 512.
redirect-next-hop WORD <1–45>
Specifies the nexthop IPv4 or IPv6 address for redirect node.
Note:
redirect-next-hop is available for demonstration purposes on some products. For more information, see VOSS Feature Support Matrix.
unreachable <permit|deny>
Denies or permits packet dropping when the next hop for the packet is unreachable.
The default value is deny.
Note:
unreachable is available for demonstration purposes on some products. For more information, see VOSS Feature Support Matrix.
vrf WORD<1–16>
Specifies the direct next hop VRF name. The name must be in the ranger of 1 to 16 characters.
Note:
vrf is available for demonstration purposes on some products. For more information, see VOSS Feature Support Matrix.
remark-dscp <phbcs0|phbcs1|phbaf11|phbaf12|phbaf13|phbcs2|phbaf21|phbaf22|phbaf23|phbcs3|phbaf31|phbaf32|phbaf33|phbcs4|phbaf41|phbaf42|phbaf43|phbcs5|phbcs6|phbef|phbcs7>
Specifies the new Per-Hop Behavior (PHB) for matching packets: phbcs0, phbcs1, phbaf11, phbaf12, phbaf13, phbcs2, phbaf21, phbaf22, phbaf23, phbcs3, phbaf31, phbaf32, phbaf33, phbcs4, phbaf41, phbaf42, phbaf43, phbcs5, phbef, phbcs6, phbcs7.
This action is a QoS action.
remark-dot1p <0–7>
Specifies the new 802.1 priority bit for matching packets: zero, one, two, three, four, five, six, or seven.
