View the mappings of network layer address to physical address to interface.
The probe adds entries on this tab based on the source MAC and network addresses in packets without MAC-level errors.
The probe populates this table for all protocols on the Protocol Directories tab with a value of AddressMapConfig equal to supportedOn.
- Click Address Map.
- Click the Address Map tab.
Address Map Field Descriptions
Use the data in the following table to use the Address Map tab.
Name |
Description |
LocalIndex |
Shows a unique identifier for the entry in the table. |
HostAddress |
Shows the network address for this entry. The format of the value depends on the protocol portion of the local index. |
Source |
Shows the interface or port on which the network address was most recently seen. |
PhysicalAddress |
Shows the physical address on which the network address was most recently seen. |
LastChange |
Shows the value of the sysUpTime when the entry was created or last changed. If this value changes frequently, it can indicate duplicate address problems. |
