Display information about the files on a USB device to view general file information.
- Click File System.
- Click the USB Files tab.
USB Files field descriptions
Use the data in the following table to use the USB Files tab.
Name |
Description |
Slot |
Specifies the slot number of the device. |
Name |
Specifies the directory name of the file. |
Date |
Specifies the creation or modification date of the file. |
Size |
Specifies the size of the file. |
