Use the following procedure to generate the private and public key pair for the specific cryptography type.
  1. In the navigation pane, expand Configuration > Security > Control Path.
  2. Click Certificate.
  3. Click the Key-pair tab.
  4. Click Insert.
  5. In the Type field, select the cryptography type.
    This software supports RSA only.
  6. In the Size field, enter the size of the key.
  7. Click Insert.
Certificate key-pair field description
Use the data in the following table to use the Certificate > Key-Pair tab.
Name
Description
Type
Specifies the cryptography algorithm used to generate the key-pair.
Size
Specifies the size of the key-pair to be generated.
Name
Specifies the name of the key-pair generated for the subject.
This name is auto-generated as the combination of key-type and key-size.
