Important
When you enable hsecure, passwords must contain a minimum of 10 characters or numbers with a maximum of 20. The password must contain a minimum of: two uppercase characters, two lowercase characters, two numbers, and two special characters.
After you enable hsecure and restart the system, change your password if you have an invalid-length password.
When you have an invalid-length password, the system displays the following message:
Your password is valid but less than mandatory 10 characters. Please change the password to continue.
Log on to the switch:
Login: rwa
Enter the password:
Password: ***
Your password is valid but less than mandatory 10 characters. Please chnage the password to continue.
Enter the new password:
Enter the new password: **********
Re-enter the new password:
Re-enter the new password: **********
Password successfully changed.
