Use the following procedure to display information about all participants in an MKA session. You can also display MKA information for a specific port participating in an MKA session.
This procedure only applies to VSP 8400 Series.
The following example displays information for all participants in an MKA session.
Switch:1(config)#show macsec mka participant
MACsec MKA Participants
Port CA MKA-Profile MKA Actor
Id Name Name Enable Priority
1/3 CA120022 extreme030519 Enabled A
1/4 CA121023 extreme031519 Enabled 14
2/2 CA122024 extreme032019 Enabled 1E
The following example displays information for a specific port participating in an MKA session.
Switch:1(config)#show macsec mka participant 1/3
The following table defines parameters for the show macsec mka participant command.
| Variable | Value |
| {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
verbose |
Displays detailed information for a specific port participating in an MKA session. |
