You can view each port and associated VRFs. You can also change the VRFs associated with the port if the port has no IP address.
VRF-Ports field descriptions
Use the data in the following table to use the VRF-Ports tab.
| Name | Description |
| Index | Specifies the slot and port. |
| Type | Specifies the port type. |
| VrfIds | Identifies the set of VRF IDs to which this port belongs. |
| VrfCount | Shows the number of VRF instances associated with this port. |
| BrouterVrfId | Shows the VRF ID for this brouter port. |
| BrouterVrfName | Shows the VRF name for this brouter port. |
| Show VrfNames | You can use this toolbar button to identify the set of VRF names to which a port belongs. |
Use the data in the following table to use the Show VrfNames button.
| VrfNames | Shows the VRF name for this brouter port. |
