You can view and manage known MAC address to IP address associations. In addition, you can create or delete individual ARP entries.
- Click IP.
- Click the ARP tab.
ARP field descriptions
Use the data in the following table to use the ARP tab.
Name |
Description |
NetAddress |
Specifies the IP address corresponding to the media-dependent physical address. |
IfIndex |
Identifies the router interface for this ARP entry:
PhysAddress |
Specifies the media-dependent physical address (that is, the Ethernet address). |
Type |
Specifies the type of ARP entry:
TimeToLive |
Indicates the time to live where the ARP is configured. |
DestIfIndex |
Indicates the slot/port on which the ARP entry was learned. For brouter interfaces this is the same value as IfIndex, but for VLAN interfaces, it designates the particular port in the VLAN on which the ARP was learned. |
DestVlanId |
VLAN ID where the ARP is configured. |
BMac |
Identifies the backbone MAC address if the entry is learned from an SPBM network. |
DestCvid |
Identifies the customer VLAN ID for a Switched UNI port. |
