View DHCP statistics to manage network performance.
- Click DHCP Relay.
- Click the Interfaces Stats tab.
Interfaces Stats Field Descriptions
Use the data in the following table to use the Interfaces Stats tab.
Name |
Description |
IfIndex |
Identifies the physical interface. |
AgentAddr |
Shows the IP address configured as the relay on this interface. This address is either the IP of the physical interface or the IP of the VRRP address. |
NumRequests |
Shows the number of DHCP and BootP requests on this interface. |
NumReplies |
Shows the number of DHCP and BootP replies on this interface. |
