Use the following options to display Layer 3 VSN with IP Multicast over Fabric Connect information to confirm proper configuration.
show ip vrf mvpn
show isis spbm ip-multicast-route [all][detail]
show isis spbm ip-multicast-route [group {A.B.C.D}][detail][source {A.B.C.D}]
show isis spbm ip-multicast-route [vrf WORD<1–16>] [group {A.B.C.D}]
show isis spbm ip-multicast-route [vlan <1-4059>][detail][group {A.B.C.D}]
show isis spbm ip-multicast-route [vsn-isid <1–16777215>][detail][group {A.B.C.D}]
show isis spb-mcast-summary [count][host-name WORD<0–255>][lspid <xxxx.xxxx.xxxx.xx-xx>]
Display Layer 3 VSN with IP Multicast over Fabric Connect information:
Switch:1>enable
Switch:1#show ip vrf mvpn
Vrf name : green
mvpn : enable
fwd-cache-timeout(seconds) : 210
Vrf name : 4
mvpn : enable
Vrf name : blue
mvpn : enable
Switch:1#show isis spbm ip-multicast-route all
SPBM IP-multicast ROUTE INFO ALL
Type VrfName Vlan Source Group VSN-ISID Data ISID BVLAN Source-BEB
Id
routed GRT 501 192.0.2.1 233.252.0.1 5010 16300001 10 el2
routed GRT 501 192.0.2.1 233.252.0.2 5010 16300002 20 el2
routed GRT 501 192.0.2.1 233.252.0.3 5010 16300003 10 el2
routed GRT 501 192.0.2.1 233.252.0.4 5010 16300004 20 el2
routed GRT 501 192.0.2.1 233.252.0.5 5010 16300005 10 el2
routed GRT 501 192.0.2.1 233.252.0.6 5010 16300006 20 el2
routed GRT 501 192.0.2.1 233.252.0.7 5010 16300007 10 el2
routed GRT 501 192.0.2.1 233.252.0.8 5010 16300008 20 el2
routed GRT 501 192.0.2.1 233.252.0.9 5010 16300009 10 el2
routed GRT 501 192.0.2.1 233.252.0.10 5010 16300010 20 el2
Total Number of SPBM IP multicast ROUTE Entries: 10
Switch:1#show isis spbm ip-multicast-route vrf green
SPBM IP-MULTICAST ROUTE INFO
Source Group Data ISID BVLAN Source-BEB
192.0.2.10 233.252.0.1 16300001 10 el2
192.0.2.10 233.252.0.2 16300002 20 el2
192.0.2.10 233.252.0.3 16300003 10 el2
192.0.2.10 233.252.0.4 16300004 20 el2
192.0.2.10 233.252.0.5 16300005 10 el2
192.0.2.10 233.252.0.6 16300006 20 el2
192.0.2.10 233.252.0.7 16300007 10 el2
192.0.2.10 233.252.0.8 16300008 20 el2
192.0.2.10 233.252.0.9 16300009 10 el2
192.0.2.10 233.252.0.10 16300010 20 el2
Total Number of SPBM IP MULTICAST ROUTE Entries: 10
Switch:1#show isis spbm ip-multicast-route vlan 501
Id
Switch:1# show isis spbm ip-multicast-route vsn-isid 5010
SPBM IP-multicast ROUTE INFO - VLAN ID : 501, VSN-ISID : 5010
192.0.2.1 233.252.0.2 16300002 20 el2
192.0.2.1 233.252.0.3 16300003 10 el2
192.0.2.1 233.252.0.4 16300004 20 el2
192.0.2.1 233.252.0.5 16300005 10 el2
192.0.2.1 233.252.0.6 16300006 20 el2
192.0.2.1 233.252.0.7 16300007 10 el2
192.0.2.1 233.252.0.8 16300008 20 el2
192.0.2.1 233.252.0.9 16300009 10 el2
192.0.2.1 233.252.0.10 16300010 20 el2
Switch:1# show isis spb-mcast-summary
SPB multicast - Summary
SCOPE SOURCE GROUP DATA LSP HOST
I-SID ADDRESS ADDRESS I-SID BVID FRAG NAME
5010 192.0.2.1 233.252.0.1 16300001 10 0x0 el2
5010 192.0.2.1 233.252.0.3 16300003 10 0x0 el2
5010 192.0.2.1 233.252.0.5 16300005 10 0x0 el2
5010 192.0.2.1 233.252.0.7 16300007 10 0x0 el2
5010 192.0.2.1 233.252.0.9 16300009 10 0x0 el2
5010 192.0.2.1 233.252.0.2 16300002 20 0x0 el2
5010 192.0.2.1 233.252.0.4 16300004 20 0x0 el2
5010 192.0.2.1 233.252.0.6 16300006 20 0x0 el2
5010 192.0.2.1 233.252.0.8 16300008 20 0x0 el2
5010 192.0.2.1 233.252.0.10 16300010 20 0x0 el2
