Use statistics to help you monitor Open Shortest Path First (OSPF) performance. You can also use statistics in troubleshooting procedures.
Display extended OSPF information:
Switch:1>enable
Switch:1#show ports statistics ospf extended
Port Stats Ospf Extended
PORT_NUM RXLS_REQS TXLS_REQS RXLS_ACKS TXLS_ACKS
1/3 0 0 0 0
Use the data in the following table to use the show ports statistics ospf extended command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...]} |
Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
