Edit system identification information, configuration file information, and perform system actions.
- Click Chassis.
- Click the System tab.
- Enter or edit the information as required.
- Click Apply.
System Field Descriptions
Use the data in the following table to use the System tab.
| Name | Description |
| sysDescr | Shows the system assigned name and the software version. |
| sysUpTime | Shows the elapsed time since the system last started. |
| sysContact | Configures the contact information. |
| sysName | Configures the name of this device. |
| sysLocation | Configures the physical location of this device. |
| VirtualIpAddr | Configures the virtual IP address that the primary CPU advertises and stores in the switch configuration file. |
| VirtualNetMask | Configures the net mask of the virtual management IP address. |
| VirtualIpv6Addr | Specifies the virtual IPv6 address. |
| VirtualIpv6PrefixLength | Specifies the length of the virtual IPv6 address prefix (in bits). |
| DnsDomainName | Configures the default domain for querying the DNS server. |
| LastChange | Displays the time since the last configuration change. |
| LastVlanChange | Displays the time since the last VLAN change. |
| LastStatisticsReset | Displays the time since the statistics counters were last reset. |
| LastRunTimeConfigSave | Displays the last run-time configuration saved. |
| DefaultRuntimeConfigFileName | Displays the default Run-time configuration file directory name. |
| ConfigFileName | Specifies the name of a new configuration file. |
| ActionGroup1 Note:
                                     Exception: revokeLicensePremier is only supported on the 5420 Series and 5520 Series. revokeLicenseMacsec is only supported on the 5520 Series. | Can be one of the following actions:
| LicenseFileName Note:
                                     Exception: only supported on the 5420 Series, 5520 Series, VSP 8600 Series, and the XA1400 Series. | Specifies the name of the license file in the /intflash directory. |
| ActionGroup2 | Specifies the following action: resetlstStatCounters—Resets the IST statistic counters |
| ActionGroup3 | Can be the following action:
| ActionGroup4 | Can be the following action:
| Result | Displays a message after you select Apply. |
| LocatorLED Note:
                                     Exception: only supported on 5420 Series, 5520 Series, and VSP 4900 Series. | Configures the system Locator LED on or off. The default is off. |
