Flush or clear the routing tables for administrative and troubleshooting purposes. The clear and flush commands perform the same function; they remove the contents of the table.
Switch:1>enable Switch:1#configure terminal Switch:1(config-if)#vlan action 123 all Switch:1(config)#clear ip route vlan 123
The following table defines parameters for the vlan action and clear ip route vlan commands.
Variable |
Value |
<1-4059> |
