This procedure applies only to VSP 4450 Series, VSP 4900 Series and VSP 7400 Series switches.
Configure Link Debounce for ports to hold the connection path until the carrier side switchover is complete.
enable
configure terminal
interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
link-debounce <0-300000>
show interfaces gigabitEthernet link-debounce [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
Configure the Link Debounce timer on port 1/2 to 300000 milliseconds.
Switch:1>enable Switch:1#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#interface gigabitEthernet 1/2 Switch:1(config-if)#link-debounce 300000
Display the Link Debounce configuration for ports 1/1 through 1/4.
Switch:1>enable
Switch:1(config)#show interfaces gigabitEthernet link-debounce 1/1-1/4
Port link debounce
PORT LINK-DEBOUNCE LINK-DEBOUNCE DEBOUNCE DEBOUNCE
NUM STATUS TIMER MILLISECONDS COUNT SUCCEEDED
1/1 Enable 1500 0 0
1/2 Enable 300000 0 0
1/3 Disable -- 0 0
1/4 Enable 4000 0 0
