Enable jumbo frames to increase the size of Ethernet frames the chassis supports.
Switch:1> enable
Switch:1# configure terminal
Enable jumbo frames to 9600 bytes:
Switch:1#(config)# sys mtu 9600
The following table defines parameters for the sys mtu command.
Variable |
Value |
<1522-9600> |
Configures the frame size support for the data path. Possible sizes are 1522, 1950, or 9600 bytes. The default varies depending on the platform:
