The switch configuration depends on whether you use factory default mode or Zero Touch Deployment.
With Zero Touch Deployment, the switch configuration consists of the following:
The ssh and sshd boot configuration flags are enabled by default.
All ports are Private VLAN isolated ports, except on the XA1400 Series.
VLAN 4048 is created as an onboarding-vlan for host-only connectivity for In Band management. On all other platforms, except the XA1400 Series, all front panel ports are members of VLAN 4048.
In Band management is enabled.
Dynamic Host Configuration Protocol (DHCP) client requests are cycled between In Band and Out of Band ports, except on the XA1400 Series and VSP 4450 Series. XA1400 Series and VSP 4450 Series support In Band management only.
Out of Band management is enabled, except on the XA1400 Series and VSP 4450 Series. XA1400 Series and VSP 4450 Series support In Band management only.
All ports are administratively enabled, except on the XA1400 Series. Only Port 1/8 is administratively enabled on the XA1400 Series, which means the administrator must plug in and use only port 1/8 for Zero Touch Deployment on an XA1400 Series.
IQAgent is enabled by default.
Zero Touch Provisioning Plus (ZTP+) for Extreme Management Center or ExtremeCloud IQ - Site Engine onboarding is enabled by default.
Initiates Zero Touch Fabric Configuration.
After the Zero Touch Fabric establishes successfully, the onboarding VLAN 4048 is automatically assigned to onboarding I-SID 15999999.
For information about IQAgent, see ExtremeCloud IQ Agent.
The switch continues to support the boot configuration flag boot config flags factorydefaults to return an existing switch to factory default configuration.
Zero Touch Deployment does not run on a switch returned to factory default configuration in this manner.
For more information, see Boot Sequence.
