Extreme Networks offers universal hardware products that support more than one Network Operating System (NOS) personality. The universal hardware products share a unified license, which is NOS agnostic.
The Base License, which is included with the purchase of the switch, enables the basic networking capabilities of the device. You can purchase additional licenses separately to enable advanced features on the switch.
Licenses are tied to the switch serial number. After you generate the license through the Extreme Networks Support Portal at https://extremeportal.force.com/ExtrLicenseLanding, you can install the license on the switch manually. You can also use ExtremeCloud IQ to obtain licenses for universal hardware switches.
The following sections detail the different categories of licenses.
A Base license gives customers the right to use Base software features on the switch.
Licenses enable advanced features not available in the Base License. The following table provides information on the features enabled by each license, if the hardware supports the feature. For information on supported features, see VOSS Feature Support Matrix.
License type |
Supported features |
MACsec License Note: Exception: 5420 Series does not currently support MACsec in software.
IEEE 802.1AE MACsec |
Premier License |
The following table lists the license types and the associated part numbers.
License Type |
Part Number / Order Code |
MACsec License for 5420 Series and 5520 Series Note: Exception: 5420 Series does not currently support MACsec in software.
5000-PRMR-LIC |
Premier License for 5420 Series and 5520 Series |
5000-PRMR-LIC |
ExtremeSwitching 5420 Series and 5520 Series switches include a one-year subscription to an ExtremeCloud™ IQ Pilot license.
The entitlement period starts the day the switch ships from Extreme Networks or an Extreme Networks distribution partner.ExtremeCloud IQ enables end-to-end network management and operations, delivering a fully integrated, extensible platform that simplifies the design, deployment, and security of networks from the edge to the data center, while simultaneously unlocking valuable IT and business insights. To activate these premium Pilot level capabilities, go to https://www.extremenetworks.com/universal-switch-xiq-pilot/.
