Configure RADIUS to authenticate user identity through a central database.
Switch:1>enable
Switch:1#configure terminal
Configure RADIUS access priority:
Switch:1(config)#radius access-priority-attribute 192
Configure RADIUS accounting to include CLI commands:
Switch:1(config)#radius accounting include-cli-commands
The following table defines parameters for the radius command.
Variable |
Value |
access-priority-attribute <192-240> |
Specifies the value of the access priority attribute in the range of 192 to 240. The default is 192. |
accounting {attribute-value <192-240>|enable|include-cli-commands} |
Configures the accounting attribute value, enable accounting, or configure if accounting includes CLI commands. The default is false. Use the no option to disable the accounting attribute value: no radius accounting enable. |
auth-info-attr-value <0-255> |
Specifies the value of the authentication information attribute in the range of 0 to 255.The default is 91. |
clear-stat |
Clears RADIUS statistics. |
cli-cmd-count <1–40> |
Specifies how many CLI commands, from 1 to 40, before the system sends a RADIUS accounting interim request. The default value is 40. |
cli-commands-attribute <192-240> |
Specifies the value of CLI commands attribute in the range of 192 to 240. The default is 195. |
cli-profile |
Enable RADIUS CLI profiling. CLI profiling grants or denies access to users being authenticated by way of the RADIUS server. You can add a set of CLI commands to the configuration on the RADIUS server, and you can specify the command-access more for these commands. The default is false. |
command-access-attribute <192-240> |
Specifies the value of the command access attribute in the range of 192 to 240. The default is 194. |
enable |
Enable RADIUS authentication globally on the switch. |
maxserver <1-10> |
Specific to RADIUS authentication, configures the maximum number of servers allowed for the device. The range is between 1 and 10. The default is 10. |
mcast-addr-attr-value <0-255> |
Specifies the value of the multicast address attribute in the range of 0 to 255. The default is 90. |
secure-flag Note:
Exception: not supported on VSP 8600 Series. |
Specifies whether RADIUS Security (RADSec) is globally enabled. The default is disabled. |
secure-profile Note:
Specifies the RADSec profile name. |
server host WORD<0–46> key WORD<0–32> [used-by {cli|snmp|web} [acct-enable] [acct-port <1–65536> ] [enable] [port <1–65536> ] [priority <1–10> ] [retry <0–6>secure-enablesecure-log-level {critical | debug | error | info | warning}secure-mode{dtls | tls}secure-profileWORD<1-16>] [source-ip WORD<0–46> ] [timeout <1–60> ] |
sourceip-flag Note:
Exception: only supported on VSP 8600 Series. |
Enable the source IP so the switch uses a configured source IP address. If the outgoing interface on the switch fails, a different source IP address is used — requiring that you make configuration changes to define the new RADIUS client on the RADIUS server. To simplify RADIUS server configuration, you can configure the switch to use a Circuitless IP (CLIP) address as the source IP and NAS IP address when transmitting RADIUS packets. A CLIP is not associated with a physical interface and is always in an active and operational state. You can configure the switch with multiple CLIP interfaces. By default, the switch uses the IP address of the outgoing interface as the source IP, and the NAS Ip address for RADIUS packets that it transmits. |
