Shortest Path Bridging MAC (SPBM) supports Layer 2 Virtual Service Network (VSN) functionality where Switched UNIs are bridged over the SPBM core infrastructure.
Switched User Network Interface (S-UNI) allows the association of local endpoints to I-SIDs based on local port and VLAN together. With switched UNI, the same VLAN can be used on one port to create an endpoint to one I-SID, and on another port to create an endpoint to another I-SID.
Use the following procedure to associate a port and MLT with an I-SID.
You must configure Switched UNI.
- Select ISID.
- On the Service tab, select a row with the type configured as elan.
- Select Switched Uni.
- Select Insert.
- Enter the VLAN ID in the Cvid field.
- Select Port or Mlt to update the interface index in the IfIndex field.
- Select Insert.
Switched Uni field descriptions
Use the data in the following table to use the Switched Uni tab.
Name |
Description |
Isid |
Displays the I-SID. |
Cvid |
Specifies the customer VLAN identifier. |
IfIndex |
Specifies the interface index of the Elan end point. |
| Bpdu | Enables or disables for an untagged end point. The default is disabled. |
| OriginBitmap | Specifies the origin information of the service associated with the I-SID Elan end point. |
MacBased |
Shows if the current entry is associated to a MAC-based Switched User Network Interface (S-UNI). |
