This procedure only applies to the VSP 7400 Series.
Perform this procedure to configure a remote IS-IS manual area.
- Select IS-IS Remote.
- Select the Manual Area tab.
- Select Insert.
- In the AreaAddr field, type the Area Address.
- Select Insert.
Manual Area Field Descriptions
Use the data in the following table to use the Manual Area tab.
Name |
Description |
AreaAddr |
Specifies the remote IS-IS manual-area in the range of 1 to 13 bytes. |
